Activity Forums Boris FX BCC Extrude EPS
  • BCC Extrude EPS
    Posted by Steve Brigantino on August 6, 2009 at 9:19 pm
    if I have a eps with 2 shapes a yellow star and a red circle behind that, when I import this into AE using the plugin the star and circle are on the same plane thus overlapping. Is there a way to avoid this or fix this?
    Please and thanks
    Boris Yamnitsky replied 17 years, 1 month ago 2 Members · 1 Reply
  • Boris Yamnitsky
    August 7, 2009 at 12:18 pm
    I’m guessing that you wish to set different extrusion depth to each contour to make them stand out. That would not be possible with BCC 3D Objects at the moment but is easy with Boris Blue (as an AE plugin). If you send me your EPS sample (boris@borisfx.com) I’d take a look.
    Boris Yamnitsky
    BorisFX
