Activity Forums Avid Media Composer BCC DVE Aspect Problem
  • BCC DVE Aspect Problem
    Posted by Tim Garber on December 26, 2007 at 3:25 pm
    I have been using BCC AVX plug-ins for a little more than 2 years. There is an apparent bug in the DVE that has needled me & I wonder if this is a known issue. When I enable motion blur, shadow, & then move my image using resize or rotate, the aspect goes wild.
    It can be corrected by scaling the X to 50%. Problem is on the last field of the effect it jumps back to normal aspect. No key framing will fix the problem completely since adding a keyframe on the second to last field will then give you a big motion blur glitch for that field.
    I have seen this consistently on BCC3 & BCC4. I am not currently running BCC5 so I cannot speak for it.
    Joe Womble replied 18 years, 8 months ago 2 Members · 1 Reply
  • Joe Womble
    December 29, 2007 at 2:29 am
    Tim,
    I haven’t noticed this on my systems, but I will give it a shot to see if it happens to me as well.
    Regards,
    Joe Womble
