Activity › Forums › Boris FX › BCC Cube
  • BCC Cube
    Posted by Simon Zimmer on July 5, 2008 at 3:27 pm
    I am trying to use the BCC Cube for BCC5 with AECS3.
    I have 6 different images that are the SAME size and I place each one for a specific face.
    But for some reason, the cube is more of a rectangle than equally sized cube.
    The only way I can fix it is if I use Scale Y and Z. I would think that if all the images are equal size, a cube would automatically be created and not a rectangle.
    What am I forgetting?
    thanks,
    Simon
    Peter Mcauley replied 18 years, 2 months ago 2 Members · 3 Replies
  • Peter Mcauley
    July 7, 2008 at 12:51 pm
    Hi Simon,
    If the media to which the Cube was applied is not square then the resulting Cube will not be square either. To prove this, try making a solid layer that is 250 x 250 pixels and apply the cube to that – it should be a perfect square. To retain the square shape while using non-square media you need to pre-comp the media so that it is square.
    I hope this helps.
    Peter.
  • Simon Zimmer
    July 7, 2008 at 12:52 pm
    You are right.
    It was a PAR issue.
    Now it works.
    Thanks for your help.
    Simon
  • Peter Mcauley
    July 7, 2008 at 3:02 pm
    I’m glad that helped.
    Cheers,
    Peter.
