Activity Forums Avid Media Composer BCC Cube effect
  • BCC Cube effect
    Posted by Rob Roams on February 14, 2006 at 2:21 pm
    I am using the BCC Cube effect, BCC3 distortion & perspective, in Avid Xpress HD. Is there a way to put video or pictures on each of the sides of the cube. I am trying to do it through the ‘face’ parameters but couldn’t get it to work. I know Avid FX lets you do it, but I do not have access to that program.
    Rob Roams replied 20 years, 7 months ago 2 Members · 2 Replies
  • Sostroud
    February 14, 2006 at 4:19 pm
    I have used the BCC cube effect successfully with Adrenaline. You have to layer the video cube sides up then apply the effect to the top layer. From there the faces can be assign as first below, second below etc… Good luck.
  • Rob Roams
    February 14, 2006 at 5:45 pm
    Great…its working. Thank You!!
