BCC Corner Pin Doesn’t Work in RED 4.1?
I’m trying to take a still picture inside a bump Map effect and pin the corners to a sightly irregular quilt rectangle on the track below. (Both the bump map/still track and the quilt are inside a 3D container).
I can’t figure out how to do it. The BCC Coner Pin help documentation says “The
Corner Pin Source menu sets the track that you want to corner pin onto the filtered track.
The choices are None, Filter Layer, 1st Below or 2nd Below. In general, the easiest method
is to place the filtered track on a track above the corner pin image.”I don’t see a Corner Pin Source menu. I have a Corner Pin Source track, but that gives me only the standard fare for sources (V1, V2, movie file, etc.), no None, Filter Layer, 1st Below or 2nd Below choices.
What does the manual mean by “filtered track” and “corner pin image”? Does that mean it wants me to apply the corner pin filter to the background track (quilt) and then add a track below that one with the image that will be pinned (bump map/still)?
