BCC blacking out clips & crashing FCS 5.1
Tim Goodwin replied 20 years, 4 months ago 5 Members · 24 Replies
Brian Conner
May 1, 2006 at 4:19 pmNot yet. My BorisFX rep has promised to let me know as soon as they resolve it.
I’ll pass on to her this new info. Apparently, there’s something in v10.4.6 that’s contributing to the problem.
Thanks, Tim.
Tim Goodwin
May 1, 2006 at 7:24 pmThanks Brian. Hopefully a solution will be found shortly.
FWIW, the plugins seem to work fine in Motion 2.1.1 which was upgraded to resolve a compatibility problem with OSX v10.4.6.
Thanks again
Tim -
Brian Conner
May 1, 2006 at 7:33 pmThey’ve given me the solution, and it works on my system.
1) Trash your FCP preferences (FCP Rescue 5 makes it more simple to do this). The important file to trash is the Obj Cache file, but the files work together, so trash all of them
2) Enable Caps Lock and start Final Cut
3) Immediately Quit FCP
4) Disable Caps Lock and start Final Cut again
Try adding a BCC4 filter. It it works, then set your FCP prefs again, and yuou should be Good To Go.
HTH.
Tim Goodwin
May 1, 2006 at 11:35 pmHello Brian
Thank you so very much!! That did it.
Thanks again
Tim
