Activity Forums Boris FX BCC AVX compatible with FCP?
  • Peter Mcauley
    July 6, 2006 at 8:51 pm
    BCC AVX is designed exclusively for Avid systems, while BCC is for hosts that use the AE API, and FCP is one of them. you would have to purchase BCC for FCP to use the filters in the FCP host environment – the BCC AVX filters will not operate in FCP.
    you can share presets between hosts though, so if you have a BCC AVX filter preset that you like in Avid, you can save out the preset and then open it up in BCC in FCP.
    i hope this helps.
    peter.
