Activity Forums Boris FX BCC AVX 3
  • BCC AVX 3
    Posted by Steve Pankow on May 29, 2008 at 5:23 pm
    This is a longshot, but I thought I’d ask anyway. Using BCC AVX verion 3 on Media Composer Adrenaline version 2.2.10 and a Quadro 980 card.
    Applying the Linear Wipe TR filter with the splitVertSoftTear preset appears to cause the incoming video clip to jitter somewhat until the wipe ends. It’s subtle, but I have to apply the filter again to a text layer above the video tracks, which makes it much more pronounced.
    Not sure if I need to make an adjustment or if it’s a possible limitation with the filter itself that has since been fixed in later versions of Continuum. Any ideas?
    Steve Pankow replied 18 years, 3 months ago 2 Members · 4 Replies
  • Peter Mcauley
    May 29, 2008 at 7:15 pm
    I just checked and can see this too but when I promote the effect to AVX 2 the problem that you describe disappears. Can you give that a shot and let me know if it works for you?
    Peter.
  • Steve Pankow
    May 29, 2008 at 7:33 pm
    I don’t see a way to promote anything and nothing comes up in the manual regarding AVX 2.0. Remember, this is version 3.0 of Continuum Complete AVX I’m talking about. Was there a version 3 upgrade that I missed at some point?
  • Peter Mcauley
    May 29, 2008 at 7:54 pm
    Hi Steve,
    Okay, there are two options for you to try … first, go to the filter and twirl down the General Controls group. Then set the Fields pop-up to Quality Optimized. See if this solves the problem. Also, make sure you are in green/green (high rez) mode in the Avid. If this does not work, then your only other option is to upgrade to BCC 5 so that you can use AVX 2, which on my screen does not exhibit the issue that you are reporting.
    Please let me know how this works for you.
    Cheers,
    Peter.
  • Steve Pankow
    May 29, 2008 at 7:58 pm
    Yeah, I was always in Quality Optimized and Green/Green…so much for that. Thanks for the help though.
