Activity Forums Boris FX BCC 8 Particle Emitter 3D – Problem or just how it is?
  • BCC 8 Particle Emitter 3D – Problem or just how it is?
    Posted by Bryan Beacraft on July 31, 2012 at 9:43 pm
    So I finally figured out how to get BCC Particle Emitter 3D to use my graphic as an emitter with an alpha channel.
    So now when I put my graphic in, simple text .psd 1920×1080, which takes up most of the frame, the text I mean and put the PE 3D to it, the emitter looks as if its a 1/4 or less of the original size. Now I know I can bring the emitter forward with the Position Z (I think, not in front of me at the moment) slider and bring it back to its intended size, but why isn’t it the same size to begin with?
    Bryan Beacraft replied 14 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
