Activity › Forums › Boris FX › BCC 8 on after effects CS5 error
  • BCC 8 on after effects CS5 error
    Posted by Nino gwapo Basa on July 4, 2012 at 6:41 am
    How can I fix this error, everytime I use a BCC 8 plug-in i get this “failed to create Directory “C:\Program Files\Adobe\Adobe After Effects CS5\Support Files\BCC Presets 8
    Javier Gonzalez replied 14 years, 3 months ago 3 Members · 2 Replies
  • Boris Yamnitsky
    July 4, 2012 at 3:02 pm
    A couple of quick suggestions: either create the missing directory by hand or use the BCC 8 installer to re-install the product. It sounds like the missing directory was accidentally deleted from your hard drive. The download can be found here:
    https://www.borisfx.com/downloads/
    If all fails contact our support team tomorrow at 888-77-BORIS or use the new handy chat feature on our home page:
    Good luck
    Boris Yamnitsky
    BorisFX
  • Javier Gonzalez
    July 5, 2012 at 6:57 pm
    Hey guys, just thought I’d reply to this.. I started a chat session w boris support and they were able to help me as i was getting the EXACT same problem as Nino
    Not sure if you ever had a trial of boris installed, but that seems to be the issue w my case.
    SOLUTION:
    -Uninstall boris completely w the installer.
    -Navigate to your hard drive > windows > system 32
    -in there will be some boris Dlls that youll also need to delete for a full wipe of the suite on your computer.
    -Next, w an admin account, run regedit
    -Navigate to HKEY_LOCAL_MACHINE > SOFTWARE > Boris FX, Inc.
    -Drop down that folder and delete all folder entries.
    -As i said earlier, my issue was imcompatibility w the various types of the plugin installed on this machine.
    -After all this is done, go ahead and do a reinstall and that should work.
    Big shout out to Jon at Boris support that helped me fix this 🙂
    good luck w your issue.
