Activity Forums Boris FX BCC 7 Motion Tracker for FCP
  • BCC 7 Motion Tracker for FCP
    Posted by Richard Boghosian on March 17, 2011 at 12:58 pm
    Dumb and Dumber: I have BCC7 for FCP, but I can’t figure out how to motion stabilze a shot. I have tracked the shot using Motion tracker, now how do I move that track info to the DVE to steady the shot?
    Thanks in advance, Rick
    Richard Boghosian
    Bogh AV Productions
    FCP 7.03 MacPro 8Gb ram Matrox MXO 2 Max
    Peter Mcauley replied 15 years, 6 months ago 2 Members · 3 Replies
  • Peter Mcauley
    March 17, 2011 at 2:08 pm
    Why don’t you use the BCC Optical Stabilizer instead … it was designed precisely with this task in mind.It’s in the BCC Time category and you just apply it to the clip that you want to stabilize, then analyze the clip and decide whether you want to lock down the shot (stabilize) or simply smooth the camera motion (smooth) via the Mode pop-up. If you choose stabilize, you can also select whether you want to lock down just the translation (xy) movement or also the rotation and zoom.
    Cheers,
    Peter.
  • Richard Boghosian
    March 17, 2011 at 2:30 pm
    Thanks so much. Perfect solution. Would still like to figure out the Motion tracker feature of BCC for other PIP type effects.
    Richard Boghosian
    Bogh AV Productions
  • Peter Mcauley
    March 17, 2011 at 3:11 pm
    Cool … glad that helped.
    For PIPs, I recommend that you use the BCC Match Move filter when you need to match the PIP movement to movement in the scene.
    Cheers,
    Peter.
