Activity › Forums › Boris FX › BCC 7 In AE Shatter Effect
  • BCC 7 In AE Shatter Effect
    Posted by Mark Santella on October 19, 2010 at 11:44 pm
    I want to drop down a bcc extruded text (stone) have it hit the ground and only crack slightly. I’ve been playing around with the settings, but can’t seem to get the effect I would like. A few cracks and some pieces falling off. Is this possible? Thanks for your help. In the meantime I will have fun and play with the settings. Thanks for your help.
    Mark Santella replied 15 years, 11 months ago 3 Members · 4 Replies
  • Peter Mcauley
    October 20, 2010 at 1:38 pm
    The effect that you have in mind is indeed totally possible with the BCC Extruded Text filter. You simply need to take manual control of the shatter effect. Here’s how:
    • Twirl down the Shatter Deformer group in the BCC Extruded Text filter control panel
    • Set the Crackability parameter to a value of 10
    • Set the Time Mode pop-up to Manual
    • At the start of the effect, enable the stopwatch parameter to generate keyframes for this parameter
    • Set the start value for manual time to 0
    • Go to where you want the cracks to be fully formed and set the value of this parameter to a very small amount, such as 0.05 – you can tweak this value to get the amount of cracks that you need.
    That’s about it!
    I hope this helps.
    Cheers,
    Peter.
  • Dirk De jong
    October 20, 2010 at 3:16 pm
    The Shatter deformer is more suited to making the extrusion seem to explode or for doing shatter wipe kind of transitions. I tried building something like what you described and posted a movie here ;
    https://borisfx.cachefly.net/borisfx/Dirk%20temp/Comp%202H264.mov
    maybe adding a good sound effect would sell it ? : )
    and the AE CS4 project here ;
    https://borisfx.cachefly.net/borisfx/Dirk%20temp/ExtrudedTextBreakage.aep.zip
    there are limitations with the shatter deformer that prevent me from making something more convincing, but we’ll keep it in mind for the next version (interaction with a “ground” floor etc.)
  • Mark Santella
    October 21, 2010 at 9:16 pm
    thank you very much
  • Mark Santella
    October 21, 2010 at 9:17 pm
    thank you
