Activity Forums Boris FX BCC 5 FXPlug crash
  • BCC 5 FXPlug crash
    Posted by Mschirad on July 18, 2007 at 5:26 pm
    I ordered, downloaded and installed BCC 5 onto my MacBook Pro, 10.4.9, running FCP 5.14 and Motion 2.12. All the plug-ins show up, but applying any of them to a clip in Motion crashes the app. Applying any to a clip in FCP renders out a nice black screen. Now I’m wondering if BCC5 is even meant to work in anything older than FCP 6 and Motion 3.
    Has anyone else been working with the new Boris Continuum Complete?
    mschirad
    http://www.wmaeug.net
    Kevin Reiner replied 19 years, 1 month ago 3 Members · 5 Replies
  • Boris Yamnitsky
    July 19, 2007 at 2:02 am
    Our testing of FXPlug package has been focused on the Final Cut Studio 2 apps as Apple made a number of significant improvements to FXPlug interface in that release. However, we’ll look into a limited support for older versions in the next update. In the meantime, the BCC4 product should run fine in FCP 5.14.
  • Mschirad
    July 20, 2007 at 4:17 pm
    Thanks for the response,
    I guess I was confused by the Boris web site’s compatibility matrix, showing 5.0 FXPlug support in FCP 5. The chart has compatibilty with Motion, but doesn’t specify the version.
    https://www.borisfx.com/product/continuum/support.php
    Is there a special procedure I should follow to get ahold of BCC 4.1? Will the serial number I received for BCC 5 FXPlug be vaild for BCC 4.1? Just to cross the “t”s and dot the “i”s, is there a particular uninstall process for BCC 5, or uninstall app available?
    Mathew Schirado
    groups.yahoo.com/groups/wmaeug
  • Boris Yamnitsky
    July 20, 2007 at 4:27 pm
    I suggest to contact our tech support at support@borisfx.com. They will set you up with the version 4.1 in FCP 5.14. Since 4.1 is a separate set of plug ins you do not need to remove the version 5 unless you really want to. Version 5 may be handy when/if you upgrade your Final Cut.
    Sorry for the confusion. We are in a transition from AE style plugs to FxPlug as recommended by Apple. Hope the transition will not be too bumpy.
  • Mschirad
    July 21, 2007 at 4:48 am
    Thank you, I’m mailing with tech support right now. I appreciate your assistance.
    mschirad
  • Kevin Reiner
    July 30, 2007 at 8:48 pm
    I am having the same problems. I emailed Boris to ask for a BCC 4 link. They told me to try to use the AE installer to install it on FCP. This won’t work because the new AE BCC 5 installer doesn’t install to FCP. I was going to try to copy the plugins from AE to FCP, but I thought they changed the architecture. Quite honestly, I don’t understand what I’m saying write now, and I am very confused.
    Can anyone answer me this question:
    How do I get Boris Continuum Complete to work on FCP 5.1.4?
    (I don’t care if its BCC 4 or 5)
    Reins
