Activity Forums Boris FX BCC 10 mocha in Premiere Pro
  • BCC 10 mocha in Premiere Pro
    Posted by Dan Luke on September 21, 2016 at 3:24 pm
    When I try to add a boris effect to a clip that has another effect with a mocha mask, I get a shadow of the mask offset on the clip. What am i doing wrong?
    Dan Luke replied 9 years, 11 months ago 2 Members · 3 Replies
  • Jon Kozenko
    September 22, 2016 at 3:52 pm
    Hello Dan,
    Do you think you can show me sample screengrabs, showing before and after, of this situation? You can send them to support@borisfx.com. Also, in your workflow of applying a new BCC filter, I presume this happens immediately when you apply the second BCC filter, rather than later, such as after enabling the PixelChooser? Lastly, what host and OS are you running?
    Thanks.
    Jon
  • Dan Luke
    September 22, 2016 at 11:31 pm
    10.10.5 mac os host is the avid and premiere version. I apply an effect, draw a mask and then as soon as i layer another effect on i get the offset without enabling pixel chooser on the second effect. I’ll send a pic.
    -dan
  • Dan Luke
    September 22, 2016 at 11:36 pm
    ok so now it’s not doing it. Maybe it just needed a reboot which i have done several times in the last 48 hours because of other PP2015.4 bugs.
