Activity Forums Apple Final Cut Pro Legacy BBC 3 and FCP 5.1.4 on G5 (PPC)
  • BBC 3 and FCP 5.1.4 on G5 (PPC)
    Posted by Mike Raff on March 13, 2007 at 5:25 pm
    I just upgraded my system to OS 10.4.8 and FCS 5.1.4. I remembered a thread from last January that said there were issues between BCC 3 and FCP 5.1.2, but was reassured by a post from Walter that said there was a patch to resolve the issue.
    << Name: walter biscardi Date: Jan 3, 2007 at 4:32:47 pm Subject: Re: 5.1.2 & Boris not compatible? BCC 3 requires an update from the Boris site to work with FCP 5.1.2 on a G5 machine. If you have an Intel machine you MUST upgrade to BCC 4 and download the script fix.>>
    Well, I went to the Boris website and the only patch I could find was “Continuum Complete 4.01 Update for Final Cut Pro 5.1 users only. This patch makes BCC 4.01 compatible with FCP 5.1.”
    So I called Boris Tech Support and was told there is no patch for BCC 3 and that I should buy BCC 4. (Which would require money that isn’t in the budget, of course. And I hadn’t remembered Walter’s mention of PPC vs. Intel issue, so I neglected to bring it up.)
    Anyway, which answer is correct: there is no patch for BCC 3? Or there is, but only on a PPC G5?
    If there is a patch for BBC 3/G5, it’s not on the Boris website anymore. If you happen to have it lying around, I would greatly appreciate it if you could send it my way.
    TIA
    Mike Raff
    Producer-Editor
    WRIC TV
    mraff@wric.com
    Mike Raff replied 19 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
