Activity Forums AJA Video Systems BB/ Blackburst/ Sync/ Genlock, seamless playback, edit
  • BB/ Blackburst/ Sync/ Genlock, seamless playback, edit
    Posted by Chris Thomsen on May 14, 2009 at 7:59 pm
    i want to integrate the Aja KI Pro into an analog studio (component). Normally every device has to be synced. On the back of the Aja KI Pro i can`t see any BB or Genlock inputs.
    Do i have to use a timebase-corrector in this case?
    Is it possible to loop an specific file seamless?
    Is it possible to divide/ truncate/ delete files by using the buttons on the front in stand-alone-mode?
    Greetings C. Thomsen
    Chris Thomsen replied 17 years, 4 months ago 2 Members · 2 Replies
  • Jeremy Garchow
    May 14, 2009 at 8:56 pm
    [Chris Thomsen] “Do i have to use a timebase-corrector in this case? “
    No, you can tell the Ki to sync over Y of the incoming component video.
    [Chris Thomsen] “Is it possible to loop an specific file seamless? “
    Yes, looping is seamless and there’s a parameter that can be set to do so.
    [Chris Thomsen] “Is it possible to divide/ truncate/ delete files by using the buttons on the front in stand-alone-mode? “
    You can create a playlist of sorts to play files, but all editing will need to be done on an NLE.
    Hope that helps,
    Jeremy
  • Chris Thomsen
    May 15, 2009 at 5:51 am
    Yes, thank you very much.
