Activity Forums Adobe After Effects Battlestar Galactica: the ‘Caprica’ look (Magic Bullet)
  • Battlestar Galactica: the ‘Caprica’ look (Magic Bullet)
    Posted by Darren Edwards on June 20, 2007 at 12:32 pm
    Hi there,
    Apols if this is misposted, but there’s no general
    post-production and/or colour correction and/or Magic
    Bullet forum to post to.
    Am currently in early pre-p grading for a sci-fi
    short (‘Everything Beautiful’) shoot during this summer.
    Normally my workflow mirrors Fincher/Miranda, and
    I’ll take screengrabs home during production, grade
    them in PShop, get pre-post approval and everything
    is speeded up wonderfully. This time, I already have
    references to work with – one of then being the Galactica’s
    Caprica from Season 2 – so I thought I’d make a start
    anyway. It’s early days on this, but I’ve got time on
    my hands (for a change).
    The link is something tosed together in Magic Bullet last
    light. General RGB or grading or Hue-Sat or maybe even insights
    into Galactica’s colourists are appreciated. Maybe they
    (colourists) used propriety software for the grading –
    who knows?
    https://www.x-gf.com/misc/everybeaut_prep_colourgrade1.jpg
    Thanks in advance,
    Darren.
    myspace.com/xgfmedia
    Kevin Hamm replied 18 years, 9 months ago 3 Members · 7 Replies
  • 7 Replies
  • Mike Cohen
    June 25, 2007 at 4:45 pm
    What is the original image? Your grading looks a bit too yellow to me – what are you trying to suggest with your colors?
  • Darren Edwards
    June 27, 2007 at 11:14 am
    The reference still (as stated) is from BG, Season 2.
    BG’s grading connotation (as is ours) is post-nuclear
    war; the planet is hotter, skies polluted, residual
    fallout in the clouds. Orange and white which reflects
    the primary colours of a mushroom cloud, I presume. The
    BG still is quite likely to be a CG still, so hence
    they found it quite easy to maintain the oranges
    and greens without a lot of colour-correction hassle.
    One obviously (of course) is to trawl the BG forums,
    but there isn’t enough hours in the day for that.
    Darren.
  • Mike Cohen
    June 27, 2007 at 5:55 pm
    Film and Video magazine had a cover story about BG’s HD workflow some time ago. Check their website.
  • Darren Edwards
    June 28, 2007 at 12:17 pm
    Cheers, mate.
  • Darren Edwards
    June 29, 2007 at 2:43 pm
    I got in touch with Mark @ Enigma about this. He was VFX on Season
    1. This was his reply:
    … awaiting permission to quote.
  • Darren Edwards
    July 2, 2007 at 2:25 pm
    Update: Mark kindly asked I didn’t reprint his
    viewpoint(s).
    Darren.
  • Kevin Hamm
    November 28, 2007 at 12:41 am
    Ok, so here’s what I’ve done to replicate the look just using Final Cut:
    Select the scene, edit timeline to taste.
    Choose from scene the brightest clip bit and double-click to put it up in the viewer.
    Go to Filters and find your Overdrive Effect Filter, which will allow you to make everything appear to be overlit.
    Then adjust to taste a bit.
    Back in filters, choose the ‘Tint’ filter, and choose a color that will give you the effective wash you are looking for.
    You can also, now, add the 3-way-color corrector to adjust your levels and tones for each level more precisely. You’ll end with the same effect.
    Now, how you translate that your system, I don’t know, but I hope this helps some.
