Activity › Forums › Apple Final Cut Pro Legacy › Batchrecord problem
  • Batchrecord problem
    Posted by Imagink on October 31, 2005 at 9:27 am
    Hi, I’m editing a doco i shot recently in Fiji, and am teaching myself Final Cut whilst editing with it and have come across a problem, and i don’t know what i could be doing wrong or how i could fix it… When i batch record, i log the clips i want to record, i select them and ONLY them in the bins, and click ‘batch’. A window then pops up and says that media associated with these clips has been found do i want to get them as well? if i either press continue without adding them, or to add them, it still picks up extra clips, called ‘unknown’ one of them which is 45 minutes in duration , and tries to pick it up from the tape. It tries, fails, tries again…. and is very very annoying. Can anyone help?? Puhlease??
    Chris Tompkins replied 20 years, 11 months ago 2 Members · 1 Reply
  • Chris Tompkins
    October 31, 2005 at 12:25 pm
    Have u recorded some clips b/4 you logged and tried batch capture? It sounds like u have clips on the hard drive already. Try “reconnect media” and search your hard drive(s) first to reconnect your media. Then what’s left – choose batch capture to load from tape.
    I’ll bet the footage from Fiji looks great…
