Activity › Forums › Adobe Photoshop › Batching videos into Gifs – possible action?
Posted by Kirsten Noel on June 12, 2013 at 3:38 pmHello,
I have a large number of videos (Pro res) I need as Gifs.
Currently, I do this:
File > Import > Video Frames to Layers
Then I run a resize image action I have made (70px x 87px)
Then Save for web > OK and save as a Gif.I’d like to create an action so I can do this for the whole batch, instead of each individual video.
Unfortunately, when I import video to layers, it creates an ‘untitled-1’ document, but I need ti keep the original file name.
Does anyone know a way I can batch the entire set of videos, keeping the original file names, resizing to 70px x 87px and then saving as Gifs?Thank you 🙂
Vijay Bharath replied 8 years, 9 months ago 6 Members · 8 Replies -
Bill Stephan
June 12, 2013 at 4:51 pmKirsten,
The easiest way to do this is using After Effects. Import your ProRes files, then in “Make Movie” set up an image sequence export with the specs you require. Each frame will be created with the file name you specify plus a sequence number (0001, 0002, etc.). When finished setting up each ProRes file, the render window will batch render everything.
Bill Stephan
Senior Editor/DVD Author
USA Studios
New York City -
Kirsten Noel
June 13, 2013 at 3:59 pmHi Bill,
Thanks for your response, but I’m working with AE CS6 where the make movie command has been removed and you no have to Add to Render Queue where I don;t see any gif options. The Adobe website says:
To create an animated GIF movie, first render and export a QuickTime movie from After Effects. Then import the QuickTime movie into Photoshop Extended and export the movie to animated GIF using Save For Web & Devices.Perhaps I’m missing something simple?
Kirsten -
Gary Hazen
June 14, 2013 at 4:17 pm[Kirsten Noel] “File > Import > Video Frames to Layers”
I think this is the source of the problem. Instead of importing the file, simply open the file in PS. I tried this and when I saved for web it retained the original file name and changed the extension to GIF.
Make an action to resize to 70 x 87
Make an action to save for web (GIF)Make an action that plays the scale action and then plays the save for web action (Scale and GIF)
Choose File > Automate > Batch > select the Scale and GIF action > select the source folder
This should batch process the files and put them in the same folder as the source files.
Give it a shot.
*Note – I wasn’t working with ProRes video for my test. I used a Quicktime movie (animation codec).
Wes Evans
October 22, 2013 at 11:23 pmKirsten, I find that this method usually results in lacking a looping mechanism. Do you remember if that was also the case for you?
Curtis Stiles
March 19, 2016 at 6:24 pmGary that’s super helpful. I’m hoping there’s one last step you might know how to do as well.
What if I want the final fize size for each GIF in the batch export to be under 5mb? or a size that I can set.
Could I still batch this all in photoshop somehow? One batch export, all gifs from videos, under 5mb and optimized based on that file size limit.
If there’s a will there’s a way
Curtis Stiles
March 19, 2016 at 7:19 pmHaven’t figured out a way to limit to or optimize around a specific file size yet without a second app, but in Photoshop CC 2015, this script allows me to automate>batch videos to gifs at a decent quality at a little less than 1MB/SEC of video:
With a video open, record this script:
1) In the timeline menu (top right of timeline) set timeline frame rate to 10fps
2) convert frames>flatten frames into clips
3) convert frames>make frames from clips
4) set the work area forward to start at your first frame
5) file>export>save for web (legacy) and choose GIF, 640×360, 128 colors, looping foreverHope this helps someone else
Vijay Bharath
December 7, 2017 at 10:12 pmHi Kirsten Noel,
I’m lagging in same area, Please let me how to do that.
Always it shows a message ” There were no source files that can be opened by photoshop”
Even I followed Gary’s method.
Thank’s
