Activity Forums Apple Final Cut Pro Legacy batching 16:9?
  • Posted by Maria Beck on July 15, 2005 at 11:28 am
    I have material on miniDV, filmed with 16:9 in the camera (Sony pd150).
    When I batch the clips (DV PAL 48Khz) they won’t open up as 16:9 – even though I KNOW this has been the case before when I worked at another computer, but still the same version of FCP = 5.
    Now I have to re-format the clips by going to Item Properties/Format and ticking the Anamorphic option, to make them open in 16:9 format. Before this happened automatically!!! Is there any setting that I should know about?
    The irritating thing is that I now have to render every single clip when moving them to the Sequence timeline, which takes ages!
    I have also tried to batch them with DV PAL 48Khz Anamorphic 16:9, but it doesn’t change anything.
    How can I batch my material so that they opens up as 16:9 without having to change their format in Item properites?
    OR: How can I change format on all clips without having to render every single clip individually when they’re on the timeline?
    Oh, I really hope you can help! The project is BIG and Im stressing myself out….
    Best regards, Maria B.
    Rob Alexander replied 21 years, 1 month ago 2 Members · 1 Reply
  • Rob Alexander
    July 15, 2005 at 3:34 pm
    Hi Maria,
    double check your capture preset, make sure the anamorphic box is checked – you’ll probably need to create a duplicate if it needs changing.
    Alternatively, put your bin into column view, select all clips and then in the anamorphic column right/ctrl click and select yes/no (not at my machine right now so I’m not 100% on whther it’s yes no or something else – but it will be pretty obvious).
    Make sure your timeline’s set to anamorphic as well.
    Good luck,
    Rob
