Activity › Forums › Adobe Premiere Pro › Batch trimming
  • Batch trimming
    Posted by Elliot Weiss on December 5, 2014 at 3:07 pm
    Hi there – this is probably a unique problem but thought I’d pose the question. If someone wanted to batch export a large quantity of clips, but change the in/out point for each clip, is that possible? For instance, say I was given 400 pieces of ProRes video. For reasons not worth mentioning, the first 4 seconds and the last 4 seconds need to be trimmed out. No other edits are needed on these clips but going through all 400 and doing this manually will really suck.
    Food for thought. If anyone knows a solution to this, please share. I have not found this function in Adobe or any other product for that matter.
    EW
    Daniel Jakistam replied 10 years, 11 months ago 4 Members · 3 Replies
  • Richard Herd
    December 5, 2014 at 5:42 pm
    This is probably not a basics question. You might want to ask in the other forums. (Don’t forget After Effects forums, either.)
    Good luck 🙂
  • Ann Bens
    December 7, 2014 at 1:06 am
    Trimming all clips at once can only be done on the timeline.
    Select Trim tool, then select all the clips in the timeline: now trim the clips.
    Adobe Certified Expert Premiere Pro CC
    Adobe Community Professional
  • Daniel Jakistam
    October 10, 2015 at 11:21 am
    Have the same question. I cant trim all in the same time. When I select all it trims only one. Do I have to hold shift of ctrl or else to trim it all? I tried different combinations and cant figure out how to do this.
