Activity Forums Apple Final Cut Pro Legacy Batch Timecode Adjustments – Adding time
  • Batch Timecode Adjustments – Adding time
    Posted by Sabreena Pe on November 12, 2014 at 4:23 pm
    I’m trying to sync footage for a documentary with audio that was recorded with timecode, but without a guide track. For some reason the timecode for the audio and video don’t match, and are off by a few seconds. Luckily the difference in time between the two seems to be consistent, so I’m thinking that I can just change the time code on the clips so that they match, and then sync everything with the multiclip function.
    I’m trying to find a way to batch calculate what the new timecodes should be, and I’ve found a macro that allows excel to recognize timecode, but it doesn’t allow you to add or subtract those time codes from eachother. Does anyone know of a way to make it so that excel can add or subtract the time codes, or if there is a program that allows you to batch calculate the timecodes?
    Bouke Vahl replied 11 years, 10 months ago 3 Members · 2 Replies
  • Nick Meyers
    November 13, 2014 at 7:23 am
    you look into QTchange, i think it is, from Video Tool shed
    but in FCP an XL spreadsheet will not help
    best and simplest way ios to line al your clips up in a timeline,
    double click the 1st on into the viewer
    Modify Mene > Timecode to bring up the modify TC window
    MAKE A SHORT CUT FOR THAT IF YOU REALLY WANT TO SAVE TIME!!!
    hte tc field should be active, and in FCP you can add and subtract values in all TC fields,
    so just +xx.xx.x (your offset) na dhitenter,
    then enter again for the tc to be modified
    you can copy paster that offest value too to save more time,
    stay in the viewer, and hit the down arrow to take you to the next clip
    hit your Modify TC shortcut
    + (paste your value)
    enter
    enter
    down arrow, etc
    are you sure you want to modify the TC of the clips?
    nick
  • Bouke Vahl
    November 16, 2014 at 3:49 pm
    QTchange has an Increase/Decrease function, just as you probably need…
    Check it out, the free demo will give you enough info if it will work for you or not!
    hth,
    Bouke
    https://www.videotoolshed.com/
    smart tools for video pros
