Activity Forums Adobe Premiere Pro Batch-sync multiple clips to an audio track
  • Batch-sync multiple clips to an audio track
    Posted by Luca Lange on October 5, 2020 at 8:45 pm
    Hello everybody,
    I have a 60min master audio recording, and around 50 clips with audio tracks. What would be the best way to sync up these individual clips to the master audio track?
    Thanks and best regards,
    Luca Lange
    Luca Lange replied 5 years, 11 months ago 3 Members · 3 Replies
  • Fernando Silva
    October 5, 2020 at 9:17 pm
    Red giant Pluraleyes it’s the easiest way to go.
  • Bret Hampton
    October 5, 2020 at 10:54 pm
    This can all be done in Premiere w/o plugins.
    In your media, select video clip and ALL audio clips, right click then Create Multicam source sequence.
    The audio clips will find and align with the master audio track.
    However if the speeds are different that will interfere.
    Do NOT use Merge Clips. Multicam is the accepted way to go
  • Luca Lange
    October 5, 2020 at 11:09 pm
    Thanks, I actually had PluralEyes installed so I gave that a try. Worked well apart from 3-4 clips which I synced manually, thanks Grinning
