Activity Forums Adobe After Effects Expressions batch single frame from many comps in que
  • batch single frame from many comps in que
    Posted by Trace Burroughs on February 27, 2012 at 6:32 pm
    Is there a script that will do the following or a method I’m not aware of. I have 100 comps in a project. Can I put them in the render cue and using output parameters or whatever instruct the que to create a 1 jpg for each of the comps to ouput. The comps are many seconds long. With a script or plug-in can I control the que to select a frame from each of the 100 comps lets say 3 seconds in on each comp and render just that one frame? Can I do this without going into each comp and adjusting the work area to one frame or going in and creating markers signiying the out put of one frame.
    Trace
    Trace Burroughs
    LME COLLECTIONS
    lme-collections.com
    Dan Fredley replied 14 years, 4 months ago 2 Members · 1 Reply
