Activity Forums Apple Final Cut Pro Legacy Batch select clips to lower sound levels in one fell swoop?
  • Batch select clips to lower sound levels in one fell swoop?
    Posted by Arturo Glass on June 10, 2011 at 5:39 pm
    I have a sequence cut up and have 4 audio tracks. I want to lower all the clips on tracks 3 and 4 to -18db. Is there an easy way to select all of them and lower the audio levels on all of them at once, or is it necessary to go clip by clip?
    Arturo Glass replied 15 years, 2 months ago 4 Members · 5 Replies
  • David Roth weiss
    June 10, 2011 at 5:45 pm
    Lower one to the level you desire.
    Copy that one.
    Use “Paste Attributes” to paste the audio to the others.
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    https://www.drwfilms.com
    Creative COW contributing editor and a forum host of the Business & Marketing and Apple Final Cut Pro forums.
  • Dan Monro
    June 10, 2011 at 7:51 pm
    Another option is to:
    select all of the audio tracks you want to modify.
    Hit “command” + “option” + “L” to get a dialog box that allows you to adjust the gain for all selected channels, either up or down by a relative amount, or adjust all to an absolute level, i.e. -18db.
    Or:
    Hold ‘control” and hit the “[” key to lower all selected by -3db at a time (the “]” key does +3db; the “-” and “+” keys +-1db). This also works for any track you’re parked over even if it isn’t selected – as long as it’s track selector light is on…
    Hope this helps,
    D
    Dan Monro
    FCP, Avid, AfterFX, Atlanta
    MacBook Pro 2.53 GHz Intel Core i5 4 GB ram
    Mac OS X 10.6.4
    NVIDIA GeForce GT 330M
    Final Cut Pro 7 Quicktime 7.6.6
    – OR –
    2 x 3.2 Quad Xeon; 16 GB ram
    Mac OS X 10.6.4
    NVIDIA Quadro FX 5600 Final Cut Pro 7.0.2 Quicktime 7.6.6
  • Jason Brown
    June 10, 2011 at 10:01 pm
    This is all great if you want to manipulate audio levels in the sequence but how about doing it at the browser level does anyone know how to do that?
  • Arturo Glass
    June 10, 2011 at 11:47 pm
    Thanks for the tip.
  • Arturo Glass
    June 10, 2011 at 11:48 pm
    Helps a lot. Thanks!
