Activity › Forums › Adobe Illustrator › Batch save layers, Storyboard Creation Workflow
  • Batch save layers, Storyboard Creation Workflow
    Posted by Davor Kampel on November 21, 2017 at 1:26 am
    Hi all! I’m currently working on a project where I’m creating a storyboard (clean) and the graphic elements I create will be used in the final animation. My workflow is: I create all the key frames in illustrator – every frame in a single group (within the group all the elements are in separate layers), then I export those groups one by one to png and psd files (the client is using psd for animation so they have to have all the layers separated inside the PSD files, since they have to be able to control and animate the elements separately). My question is: is there a faster way to export all the layers, is there a batch feature for this? Or should I go about this in an entirely different way? Thanks!
    Davor Kampel replied 8 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
