Batch Replacing Media Files
Posted by Gabriel Solomon on May 17, 2013 at 10:16 pmI have a vegas project that was edited with Standard definition .MPG files.
I have High Definition M2TS files with the same file name that I would like to use.Is there any way to tell vegas to look for the files in the HD folder and replace all the files without having to do each one individually.
Gabriel Solomon
LifeCapture Images
http://www.lifecaptureimages.comEllen Maurer replied 9 years, 7 months ago 4 Members · 7 Replies -
Aleksey Tarasov
May 18, 2013 at 5:33 pmVegas can’t do it, unless you use third-party extensions to replace media files
Ellen Maurer
February 4, 2017 at 2:00 pmHello!
Please tell us some third-party tools.
For example, Replace Media of Vegasaur doesn’t help.With thanks,
Ellen -
Ellen Maurer
February 4, 2017 at 2:30 pmSomething slightly different from what original poster wanted.
For example, I have in a folder these files which are used in a single project:ab.mp4
abc.mp4
abcd.mp4I renamed them like this (they are in the same folder):
ab-2017.mp4
abc-2017.mp4
abcd-2017.mp4When I open their project file I get the obvious promt which asks me what to do for the “missing” files.
Is really easy to right click each of the three of them and choose replace file.
But what to do if there are several files like that already used in a project.
Again, I really needed those files renamed.
And I’m just wondering if there is an easier way to replace those files. -
Aleksey Tarasov
February 4, 2017 at 4:46 pmI don’t know a tool that can batch replace renamed files.
Aaron Star
February 5, 2017 at 6:03 pm1) Take all the ABC.mpg files and put them in an MPG sub folder.
2) Put all the ABC-2017.mp4 in an MP4 subfolder.
3) Open vegas and when prompted to find the files, point vegas at the abc-2017.mp4 files.
4) Then adjust your project settings to match the new file format.
5) verify placements of L3 graphics and any pan/crops.
Your new ABC-2017.mp4 files will need to be frame for frame duration accurate as the originals. If they are not, you will need to sort that out before you attempt step 3.
This is a pretty standard “Proxy Editing” technique.
Ellen Maurer
February 12, 2017 at 10:02 pmHello.
My (exactly the same)
ab.mp4
abc.mp4
abcd.mp4files are just renamed into
ab-2017.mp4
abc-2017.mp4
abcd-2017.mp4Same size, resolution, extension.
When I renamed the files, they were already used in my project. And now I must work on that project with those same files. Because they are renamed, vegas promts the usual screen with “missing” files.
