Activity Forums Adobe Premiere Pro Batch replacing clips in CS4
  • Batch replacing clips in CS4
    Posted by Nick Hill on March 25, 2009 at 8:17 pm
    There’s probably a really simple answer to this but I can’t think what it is. In AE, if you open a project that references a load of clips in, say, a folder called H:somewhereMarch09 and that folder has been moved to S:somewhere_elseMarch09, all you have to do is replace one of the however many clips AE can’t find and it will automatically find the rest again (as long as the folder structures are the same). In Premiere there seems no way to do this. I moved a load of XDCAM EX clips from a slow disk to a faster disk, and want to relink them all (there are probably 200 or so) without doing them all manually. Is there a way to do this? Doing them manually is a proper pain in the bum, because each clip is in a separate folder so you have to navigate in, link the clip, then back out again and into the next folder for the next clip.
    Thanks in advance
    Nick
    Gleb Galkin replied 16 years, 4 months ago 2 Members · 2 Replies
  • Nick Hill
    March 25, 2009 at 8:26 pm
    Edit….. I’ve found a (marginally) quicker way than relinking every clip, which is this:
    – Import the folder containing all the EX clip folders
    – Alt-drag each clip over its corresponding offline clip in the timeline.
    It’s not perfect at all (who am I trying to kid, it’s a ballache) but it’s a little faster at least.
  • Gleb Galkin
    May 27, 2010 at 3:20 am
    I found a very quick solution for this problem.
    It is completely described here
    It’ll take few seconds to migrate Premiere Pro project.
    Let me know if you will still have questions
    Gleb Galkin
    http://www.laVcinema.com
