Activity › Forums › Apple Final Cut Pro Legacy › Batch Rendering ?
Batch Rendering ?
Posted by Adam Taylor on January 9, 2008 at 11:07 amI know you can do Batch Capture and Batch Exports, but i really could do with a way to do Batch Renders of multiple sequences.
I am doing lots of tagged versions of commercials, so have many individual sequences all in need of rendering as the almost final stage. It would be much more efficient if i could do all the necessary work in each sequence in one big session, then highlight all the sequences in the Browser and have FCP render them all one after the other whilst i have a break away from the screens.
Anyone if this is possible ? or of a workflow that can avoid having to manually render each sequence and still lets me keep each sequence as a separate entity?
tia
AdamEditor/Mixer
Character Options Ltd
Oldham, UKCharlotte Johnson replied 14 years, 5 months ago 6 Members · 12 Replies -
Anonymous
January 9, 2008 at 12:04 pmHi there,
When you step away for a break from the screens just ensure you have set your autorender settings under “Final Cut Pro > User Settings” to something like 1 minute and ensure the option that reads “open sequences” is showing.
Also, under the “Sequence” drop down menu ensure you have all types of renders ticked – then FCP will render EVERYTHING in ANY sequences that are open in the timeline window.
Hope that helps!
Adam Taylor
January 9, 2008 at 12:39 pmDoh !!
Of course…it all makes sense now.
It used to bug me that fcp would render away anytime i left the machine for awhile, so i switched it off wondering what the point of it was…now i understand.
thanks the info – extremely useful!
adam
Jussi Lehto
January 9, 2008 at 12:42 pmHi
You can also select multiple sequences in browser
and hit render selected (command+r).TJL
Anonymous
January 9, 2008 at 1:09 pmGlad to be of help…
Jimmy Brunger
January 9, 2008 at 2:52 pmWow…Premiere could really do with that function. Does the FCP autorender function enable while you’re working (like Background Rendering in AE/Nucleo or Timemagic on Quantel)? That’d be awesome. Or is it just when you’re not working on the Mac for an amount of time?
Also, does FCP have a Batch Encode workflow for multiple timelines>MPEG? Premiere’s use of Aodbe Media Encoder means you have to do one at a time..which is VERY annoying!
Thanks.
*Production Studio Premium CS2 / *Combustion 3 / Mocha v1
Win XP Pro SP2 / Intel P4 3GHz / 2GB RAM / GeForce FX5200 / DeckLink Pro / Roland DS-5 monitors / Sony BVM-20G1E / DVS SDI Clipstation / Wacom Intuos 3 A4 / 110GB boot/80GB media/600GB RAID-0 -
Adam Taylor
January 9, 2008 at 2:58 pmno- its not a background process, but that does give you a good excuse to get away from the screen for a break.
yes – it does have batch encode for multiple sequences. Also not a background process.
adam
Editor/Mixer
Oldham, UK -
Jimmy Brunger
January 9, 2008 at 3:02 pmOoohh…now I’m seeing some very good reasons to check out FCP.
Steve Eisen
January 9, 2008 at 3:03 pmFCP does not render in the background.
In Compressor, you can batch encode. Compressor also allows you to cluster multiple networked computers to distribute encoding.
You will find some very helpful videos on what Final Cut Studio can do here:
https://www.apple.com/finalcutstudio/Steve Eisen
Eisen Video Productions
Director-At-Large
Chicago Final Cut Pro Users Group -
Jimmy Brunger
January 10, 2008 at 10:46 amCheers Steve, yeah I would check that out..if I had an upto date version of QT..which I can’t install cos it b*ggers up Premiere with the rubbish Blackmagic drivers I have. JOY!
Hello Macworld, hello FCP, goodbye current woes! (Probably hello to new ones though..)
Charlotte Johnson
April 10, 2012 at 8:42 pmHi
I have FCP 7 and tried several time to batch render 3 separate seqs by selecting them all in the browser and hitting cmd + r, but nothing happens!
Any ideas…..?
:-s
