Activity Forums VEGAS Pro Batch Rendering
  • Batch Rendering
    Posted by Ozvideo on November 20, 2005 at 1:46 am
    I may be wrong but I was under the impression that Vegas 5 could do a stream of different rendering jobs. I this is the case where does one find this option to batch render?
    Ozvideo replied 20 years, 10 months ago 4 Members · 6 Replies
  • Peter Wright
    November 20, 2005 at 3:50 am
    Under Tools > Scripting.
    Peter Wright
    Perth, Western Oz
    http://www.allroundvision.com.au
  • Wayne Starick
    November 20, 2005 at 5:35 am
    If you want flexibility and control over rendering, have a look at the Veggie toolkit from Peachrock. It’s not free, but it is an extremely powerful and flexible tool.
    I can thoroughly recommend it!
    Go to https://www.peachrock.com/software/veggie-toolkit.html
    Wayne Starick
    If there is no Internet in heaven – I am not going!
  • Ozvideo
    November 21, 2005 at 12:51 am
    Thanks for that information. I find it interesting that the batch rendering options are available for a great many formats. Some options are missing however, for instance I only recently found out you could get Vegas to render to other codec’s like DIVX & XVID & they aren’t on this batch render list.
  • Peter Wright
    November 21, 2005 at 1:46 am
    Not sure about this – I don’t appear to have Divx or Xvid available under my Render As choices, unless it’s hidden as a subset of something else.
    So, it may be that you first have to purchase these codecs.
    If you do perhaps they will then appear under the batch render list. Conjecture only – maybe someone who knows can confirm.
    Peter Wright
    Perth, Western Oz
  • Edward Troxel
    November 21, 2005 at 2:41 am
    They are if you create your own presets that use those options! Just go to File – Render As – pick AVI as the type and then click on CUSTOM. Now pick the desired codec and any other options you desire and save your own preset. It should then appear in the batch render list.
    Edward Troxel
    JETDV Scripts
  • Ozvideo
    November 21, 2005 at 6:48 am
    I suspect that if you were to actualy use these other codec’s in Vegas that you can create files that are single pass only.
