Activity › Forums › VEGAS Pro › Batch Render
  • Batch Render
    Posted by Matthew Jeschke on June 7, 2011 at 5:17 pm
    I have a rather large project to render. It comes out to about 5 hours worth the 15 minute videos for youtube. I’m currently rendering, then walking away for an hour then coming back.
    Is there one a faster way to render.
    Or two a way to batch up / queue up renders?
    John Rofrano replied 15 years, 3 months ago 2 Members · 1 Reply
  • John Rofrano
    June 7, 2011 at 8:48 pm
    So are you saying that you have 20 projects that you need to render individually? If so, you could use a script like VASST Ultimate S Pro or Sony Vegas Pro Production Assistant. They will both batch render project files and a whole lot more.
    You can also drop all of the smaller projects into one big project and place regions around each and use the built-in Batch Render script to render the regions to separate files. It will use the region names as file names.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
