Activity Forums Adobe After Effects Batch Render / Replace Files in After Effects With Same Effect
  • Batch Render / Replace Files in After Effects With Same Effect
    Posted by Frankie Jones on June 27, 2016 at 10:00 pm
    Is there a way to automate replacing “Longer Clip” clip with 20 other clips one after another (all of exactly same length with transition point at same time, so positioning of transition is not an issue) and batch render them all out? If I did it by hand I would have to render the clip, alt drag a new clip to replace Longer Clip then render that, then next clip and repeat 20 times. I should end up with 20 different files each with a different clip with that transition effect added running from pressing Render once ideally.
    What’s the quickest way of doing this?
    Frankie Jones replied 10 years, 2 months ago 1 Member · 1 Reply
