Activity Forums VEGAS Pro Batch Render – cannot “reach” button to render regions
  • Batch Render – cannot “reach” button to render regions
    Posted by Bob Ridge on December 28, 2016 at 4:21 am
    Hi! I just got a new Dell XPS 15 laptop & love it so far. Using Sony Vegas Pro 12. I have a project set up with dozens of regions to be rendered as separate clips. However, when I go to “batch render,” the interface is scrunched up to the point that the “render regions” options is not visible, and the box cannot be expanded. I’ve tried changing the laptop’s display resolution (everything from 4k to 800×600), as well as the font size display percentage (100-225%), and while everything else in Vegas changes, the dialog box looks the same every time. Any ideas? Thanks in advance!
    Bob Ridge
    Ole Kristiansen replied 9 years, 8 months ago 3 Members · 4 Replies
  • Bob Ridge
    December 28, 2016 at 4:29 am
    Update: I figured out how to use keyboard commands to toggle & select radio buttons, so I was able to “blindly” select the regions button & it seems to be working. That said, I’d prefer to be able to see what I’m doing, obviously.
    Bob
  • Bob Ridge
    December 28, 2016 at 4:48 am
    Update: A simple reboot expanded the box. Not all the way, but enough for me to see the regions button to click it. The “go” button is still hiding behind the radio buttons, but I can click the edge of it to start the renders. Good enough for now. Still a mystery, though. I wonder if with this new laptop, I’m missing a smaller or scalable system font that is intended to be in that part of the dialog box instead of what appears to be a default Arial font.
    Bob
  • Steve Rhoden
    December 28, 2016 at 7:54 am
    Its probably an issue caused by your graphics/video card also….
    Steve Rhoden (Cow Leader)
    Film Maker & VFX Artist.
    Owner of Filmex Creative Media.
    Samples of my Work and Company can be seen here:
    https://www.facebook.com/FilmexCreativeMedia
  • Ole Kristiansen
    December 28, 2016 at 8:13 am
    Sony Vegas Pro 13 – doesn’t scale right on my 4k/UHD monitor scaled to 150%
    You need Magix Vegas Pro 14 !
