Activity › Forums › Apple Final Cut Pro Legacy › Batch rename clips in a bin
Posted by Tony Sarafoski on August 20, 2007 at 1:33 amI
Lee Berger replied 19 years, 1 month ago 3 Members · 3 Replies -
Lee Berger
August 20, 2007 at 10:44 pmI haven’t tried this but you could rename the clips in the finder using a batch renaming utility such as https://publicspace.net/ABetterFinderRename/ I’m sure there are others.
Then you could import the renamed clips into a new bin and toss the original clips.
Lee Berger
http://www.leebergermedia.com -
Neil Ryan
August 21, 2007 at 12:00 am[Lee Berger] “rename the clips in the finder using a batch renaming utility”
and if that works, relink the media to the clips, then go to Modify … Rename … Clips to File (renames the FCP clip names to match the files they are linked to.)
tell us how you go.
Neil.
Lee Berger
August 21, 2007 at 12:29 am[Post Man] “Modify … Rename … Clips to File (renames the FCP clip names to match the files they are linked to.)”
The original poster will need FCP 6 to do that. By importing the clips renamed in the Finder, the bin names and file names will match.
Lee Berger
