Activity Forums Adobe Premiere Pro Batch remove Offline Files
  • Batch remove Offline Files
    Posted by Joseph Freeman iii on March 28, 2018 at 6:06 pm
    I have received a project with 800+ offline file references in a CC2018 project.
    Is there a way to remove all offline references, rather than search “offline” and manually select & delete the listed offline references?
    Thank you
    Joseph Freeman iii replied 8 years, 5 months ago 1 Member · 1 Reply
  • Joseph Freeman iii
    March 29, 2018 at 1:47 pm
    In this case, all material is in multiple bins…otherwise a painless solution.
    I just went thru and manually removed all offline items…the project loads quickly without all that overhead and overall “seems” to be more responsive.
    Thanks for responding.
