Activity Forums Media 100 Batch ReAcqurie-Nada
  • Batch ReAcqurie-Nada
    Posted by Mark Foerster on May 4, 2009 at 9:19 pm
    I am trying to Batch re-acquire a program but when I try (from a timeline or Bin) I get no clips for ReAcquire. They were imported using an hdcam deck with timecode – any ideas?
    thanks
    Mark Toronto
    Floh Peters replied 17 years, 4 months ago 3 Members · 2 Replies
  • Fermin Branger
    May 4, 2009 at 10:57 pm
    Have you changed the CODEC setting in Project Settings yet?
    It seems like you haven’t said to Media100 that you want to re-acquire media in a better (or other) quality.
    Fermin Branger
    ALFARERIA CINEMATOGRAFICA
    Caracas, Venezuela.
  • Floh Peters
    May 5, 2009 at 5:52 am
    [Fermin Branger] “Have you changed the CODEC setting in Project Settings yet? “
    Or if they do not show up in the Batch Reacquire window at all, click on the “!” button in the middle row. Most likely your clips will show up with a “standard mismatch” warning, which means that e.g. your clips are 16:9 and your hardware is currently set to 4:3, or that your clips are HD and your hardware is set to SD. Correct your hardware settings and your clips should show up.
