Activity Forums Adobe Premiere Pro Batch re-Link media with a different extension
  • Batch re-Link media with a different extension
    Posted by Todd Schmidt on January 13, 2015 at 4:56 pm
    I haven’t seen a solution to this, but the question has been posed.
    I was sent a hard drive with media to edit. I had to change the file extension of all the clips (long story in another post). The clips however, are named the same.
    I’m working with a director in another state who has the same clips I had to change the file extension to. He has edited a rough cut using the the QT clips and sent me the PP Project. I’m trying to re-link the clips, which total 350. I can manually re-link these to my clips with the different extension….which is a pain. I would like to batch link these. Is there any way to do this?
    We are both working in CC2014 v8.1
    I’m in Windows, he’s on a Mac, which is no problem as we’ve worked on films like this before.
    Also, the reason I had to change the ext is a ling story. I just need to know if batch re-linking is possible with a different ext.
    Todd
    Mads Nybo jørgensen replied 2 years, 5 months ago 8 Members · 9 Replies
  • 9 Replies
  • Tim Kolb
    January 13, 2015 at 6:26 pm
    My guess would be that the different extension might be a deal-breaker for a bulk-replace
    But…have you given it a shot? If you try to launch the project and it asks for missing media (because you’ve changed all the file extensions of course), can you point the first one to its re-named version and see if the rest re-link?
    TimK,
    Director, Consultant
    Video Producer at I-CAR
  • Tero Ahlfors
    January 13, 2015 at 6:43 pm
    [Todd Schmidt] “Is there any way to do this?”
    There are a bunch of settings in the link media window. One of which is if the linking uses the extension.
  • Alex Udell
    January 13, 2015 at 7:03 pm
    take a look at this 3rd party solution
    may help:
    reLink reTooled
    https://www.retooled.net/?page_id=784
    Alex Udell
    Editing, Motion Graphics, and Visual FX
  • Kevin Monahan
    January 13, 2015 at 8:27 pm
    Right Tero,
    [Tero Ahlfors] “One of which is if the linking uses the extension.”
    Have you tried this?
    Kevin
    Kevin Monahan
    Support Product Manager—DVA
    Adobe After Effects
    Adobe Premiere Pro
    Adobe
    Follow Me on Twitter!
  • Todd Schmidt
    January 13, 2015 at 9:54 pm
    Hey guys,
    I tried re-linking with the re-link dialogue box and unchecked the file extension tick, still no go. As far as the re-Tooled program, I haven’t tried it yet. There is no trial version of it so I’m a bit unsure of buying it.
    BTW I posted this in the Adobe forums and they deleted my post for some reason.
    Todd
  • Kevin Monahan
    January 13, 2015 at 10:48 pm
    Hi Todd,
    [Todd Schmidt] “I tried re-linking with the re-link dialogue box and unchecked the file extension tick, still no go. “
    Sorry about that. You can file a bug report here: https://adobe.ly/ReportBug
    It should be working.
    [Todd Schmidt] “BTW I posted this in the Adobe forums and they deleted my post for some reason.”
    Feel free to repost. I don’t know how that happened.
    Kevin
    Kevin Monahan
    Adobe After Effects
    Adobe Premiere Pro
    Adobe
  • Azhar Pangesti
    March 26, 2024 at 2:32 pm
    So I found out that while opening the project and it complain about missing files.. the uncheck file extension is not working –it will not find the other files.
    What I did :
    Klik offline all.. and let the project open.
    Once it open, I select all the offlines and click relink..
    The same offline/relink dialog box open.
    But this time I can uncheck the extension and it will relink all the rest (with different extension) as expected.
  • Eric Santiago
    March 27, 2024 at 12:51 pm
    I sure hope so after a decade of it being wonky 🙂
    March 28, 2024 at 12:14 am
    Still Wonky…
    Currently dealing with On-Line on a project where all the proxies were created, turning the mono audio track into stereo on the Proxy. So I am currently faced with manually replacing all the clips across 28 minutes of off-line edit.
    And, I am not even using the camera audio – but Adobe PPRO wants the files to match.
    I kind of understand why, but then I don’t.
    Shall share if I find a “quick” solution to that problem.
    Unless someone here already has the answer?
    Thank you!
