Activity Forums Adobe After Effects Batch processing titles
  • Batch processing titles
    Posted by Graham Macfarlane on April 29, 2011 at 6:37 pm
    I have a huge number of separate video files which all need a simple bit of text to be overlayed in one corner.
    I could easily use AE or premiere for this but I believe it would have to be done one video at a time and there are 1500 videos plus to process.
    Is there some simple App that is capable of batch processing such a task?
    Cheers
    Graham Macfarlane
    3D animator and VFX specialist
    London UK
    Graham Macfarlane replied 15 years, 4 months ago 2 Members · 2 Replies
  • Kevin Camp
    April 29, 2011 at 7:29 pm
    many compression utilities can add a watermark to files, and you can usually set those up to do a batch job.
    compressor, for example can add text and/or a watermark to footage. mpeg-streamclip can add a watermark too (settings are found by clicking the ‘adjustments’ button from the export settings).
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Graham Macfarlane
    April 30, 2011 at 10:11 am
    mpeg-streamclip works a treat!!
    Thanks Kevin!
    Graham Macfarlane
    London UK
