Activity › Forums › Adobe After Effects › “batch processing” interpret footage
  • “batch processing” interpret footage
    Posted by Criis Daw on May 24, 2010 at 8:18 pm
    Can anyone think of a way to import around 200 gifs and then interpret the footage to loop 200 times and set the frame rate to 10 frames per second AUTOMATICALLY
    obviously i can open the interpret footage dialog box for each gif and do it manually but is there a way to save me the tedium ?
    thanks
    Criis Daw replied 16 years, 4 months ago 2 Members · 4 Replies
  • Adriano Moraes
    May 24, 2010 at 8:24 pm
    You could interpret on of the files then right click and select “remember interpretation” then choose all the 199 others and apply the interpret footage on them under the same menu.
    Hope it helps.
    Cheers.
  • Adriano Moraes
    May 24, 2010 at 8:25 pm
    Sorry I meant:
    You could interpret one of the files
    sorry ’bout that.
  • Criis Daw
    May 24, 2010 at 8:36 pm
    excellent
    it works
    thank you very much
  • Criis Daw
    May 26, 2010 at 10:16 am
    thanks dave,
    the first method worked fine. But skinning cats is hobby of mine so new knives are great 🙂
