Activity Forums Adobe Premiere Pro Batch processing clips with scripts?
  • Batch processing clips with scripts?
    Posted by Max Stein on October 27, 2011 at 11:11 am
    Hi!
    Haven’t used Premiere in years. Am starting again with 5.5. I could use some help.
    I have 60p footage I want to interpret to 24p. Also turn off audio. I can do this using the modify menu.
    But I have about 30 clips. Can I create a script, or like PS Action to apply these changes to all selected clips?
    Does Premiere have a similar way to record a repetitive action and play them back like Actions?
    PS: If scripting would work, I was thinking of being able to send a clip to AE and run Warp Stabilization and then bring the processed clip back. Is that possible?
    Max
    Angelo Lorenzo replied 14 years, 10 months ago 2 Members · 1 Reply
  • Angelo Lorenzo
    October 29, 2011 at 8:38 pm
    At this point, the official answer seems to be no. Adobe Extendscript Toolkit has the ability to access and control Premiere but there is no documentation or sample scripts as to what the Javascript function calls are, if there is any.
    The best I’ve done is launch a file open dialog using Extendscript
