Activity Forums Adobe Photoshop Batch Process tiffs to jpg
  • Batch Process tiffs to jpg
    Posted by Thad Ciechanowski on June 25, 2009 at 12:55 pm
    I’m trying to batch process about 1500 16 bit tiffs to 8 bit jpgs. I record a new action: open the file, convert the bit mode to 8, save as a jpg in a different folder and then close.
    However, when I run the batch it saves the first image as a jpg and the rest as 16bit tiffs, basically just creating a copy in the new folder. I tried using PS 7 and PS CS3, on both a Mac and PC. Same thing always happens.
    I’m not sure what I could be doing wrong… any ideas?
    Thad
    Thad Ciechanowski replied 17 years, 2 months ago 2 Members · 3 Replies
  • Thad Ciechanowski
    June 26, 2009 at 12:57 pm
    Just in case anyone’s interested or encounters this issue, here’s how I did a work around. You’ll need After Effects:
    I imported my 16 bit tiffs into AE as a clip sequence and then exported the sequence as an 8 bit JPG sequence. Tada!
    http://www.dijitmedia.com
  • Richard Harrington
    June 26, 2009 at 4:53 pm
    File > Script > Image Processor
    Richard M. Harrington, PMP
    Author: Photoshop for Video, Understanding Adobe Photoshop, Final Cut Studio On the Spot and ATS:iWork
  • Thad Ciechanowski
    June 26, 2009 at 6:41 pm
    I primarily use PS 7.0 which I believe doesn’t have that feature. The CS2 version I have is on my Mac (Powerbook G4) which is considerably slower than my current PC configuration. I’ll keep that in my back pocket for next time though.
    Thanks again.
    Thad
