Activity Forums Apple Final Cut Pro Legacy Batch process QTs into AIFs
  • Batch process QTs into AIFs
    Posted by William Gadea on June 15, 2005 at 11:56 pm
    I’m involved in animation production and will need to extract AIF sound from a whole bunch of Quicktimes (probably around 300 or so.) Any ideas on how this could be done in an automated, batch process? I guess I could set up a render queue in After Effects but it seems like there should be an easier way.
    William Gadea replied 21 years, 2 months ago 4 Members · 4 Replies
  • Steven Gonzales
    June 16, 2005 at 12:57 am
    Quicktime has a scripting dictionary for Applescript, so you should be able to create something without too much trouble:
    https://www.apple.com/applescript/quicktime/
  • Scott Witthaus
    June 16, 2005 at 1:05 am
    I use Cleaner. Drag them in, set up your parameters, hit go, and go home.
  • Jeremy Garchow
    June 16, 2005 at 1:22 am
    As Scott says, Cleaner is great, but to save you some money, you should be able to set this up in compressor. Set up your own custom preset with destination & filename, include just the audio no video, apply the preset to all movies and let the computer do the work.
    Jeremy
    G5 Dual 2Ghz <> 4GB RAM <> FCP 4.5 <> Kona 2
    ATTO 42XS <> Huge Systems 1.25 TB 4105 Fibre
  • William Gadea
    June 16, 2005 at 3:29 am
    All great suggestions, thank you.
    New York-based Editor-Compositor
