Activity Forums Compression Techniques Batch merge 50 audio tracks with corresponding video tracks using FFmpeg.
  • Batch merge 50 audio tracks with corresponding video tracks using FFmpeg.
    Posted by Freddie Hill on August 8, 2011 at 3:56 pm
    Is there any way to batch merge 50 audio tracks with corresponding video tracks without re-encoding, using FFmpeg?
    I have run into an instance where I have to do this and wondered if it’s able to be done in a ‘batch’ procedure. I know you can do this using QT pro but you have to merge everything singularly.
    Any advice on this would be great.
    Freddie
    Michael Rampe replied 15 years, 1 month ago 2 Members · 1 Reply
  • Michael Rampe
    August 27, 2011 at 12:35 am
    [Freddie Hill] “Is there any way to batch merge 50 audio tracks with corresponding video tracks without re-encoding, using FFmpeg?”
    yep. Write a shell script with a ‘while’ or ‘for’ loop to run through them all.
    Use -acodec copy -vcodec copy to not recompress.
    Michael
