Activity › Forums › Apple Final Cut Pro Legacy › Batch List Only Partially Imports
  • Batch List Only Partially Imports
    Posted by Deandre’ Vidale on February 23, 2010 at 6:56 pm
    Hello all,
    I’ve been attempting to import a batch list into Final Cut Pro 6 but only the first clip appears when Final Cut performs the import.
    Everything about the list appears to be in order. Batch lists that are exported from FCP’s Browser window and re-imported work without a problem.
    The data for my batch list is being exported from the Timeline as XML, then converted to a batch list using an Automator workflow script. The resulting text file appears properly formatted, but only the first item will import. Any ideas? Thanks.
    Deandre’ Vidale replied 16 years, 7 months ago 2 Members · 5 Replies
  • Russell Lasson
    February 24, 2010 at 4:27 am
    [DeAndre’ Vidale] “The data for my batch list is being exported from the Timeline as XML, then converted to a batch list using an Automator workflow script. The resulting text file appears properly formatted, but only the first item will import. Any ideas? Thanks.”
    Can you post any examples of the formatting?
    -Russ
    Russell Lasson
    Colorist/Digital Cinema Specialist
    Color Mill
    Salt Lake City, UT
    http://www.colormill.net
  • Deandre’ Vidale
    February 24, 2010 at 2:35 pm
    Sure. Here are links to the files. FCP Batch List is a list generated from a FCP browser window. NewBatchList is what I created through XML and Automator.
    FCP Batch List
    https://dvidale.webs.com/FCP%20Batch%20List
    New Batch List
    https://dvidale.webs.com/NewBatchList.txt
    Thanks.
  • Russell Lasson
    February 24, 2010 at 4:49 pm
    It looks to me like the xml/automator batch list isn’t properly formatted. Try ordering the columns in the same order, using more digits in the duration field, and making sure that there is only one tab between columns.
    -Russ
    Russell Lasson
    Color Mill
    Salt Lake City, UT
  • Deandre’ Vidale
    February 24, 2010 at 6:23 pm
    Unfortunately the Automator action is responsible for the order of the columns, as well as the number of zeros in the Duration, and I have no idea how to edit Automator actions.
    I’ll see if I can get in contact with the creator and see if he remembers what he did three years ago.Thank you very much.
  • Deandre’ Vidale
    February 25, 2010 at 3:50 pm
    Russell,
    Thanks for giving your input. I managed to get in contact with the creator of the Automator script on Twitter and the source code is in a programming language way outside of my skill set. I’ll just have to find another way.
