Activity › Forums › Apple Final Cut Pro Legacy › Batch List Exporting Problem
Posted by Karen Avizur on November 13, 2009 at 12:18 pmI was trying to export a batch list of my footage and import it into Excel, and it worked fine, except all the information in the Comment 1 colum isn’t there. What could be the problem?
Jerry Hofmann replied 16 years, 10 months ago 2 Members · 3 Replies -
Jerry Hofmann
November 14, 2009 at 1:08 pmThat’s odd indeed.. it should be there if the column is open in the browser… could sure be a bug or someting… try a single clip with the test to see if you can copy and paste to say a description column… OR export ONLY what you want in excel by right clicking on columns you don’t care about first.. like frame sizes maybe? or codecs? etc…? that way you’re exporting fewer columns and might get that comment column to show up?
Jerry
Apple Certified Trainer
Author: “Jerry Hofmann on Final Cut Pro 4” Click here
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO, CD’s
Karen Avizur
November 14, 2009 at 1:14 pmThanks for the response, but apparently you can’t export batch list info for bins, which was what I was trying to do. I got a message from someone else. 🙂
Jerry Hofmann
November 16, 2009 at 7:48 pmThat’s right, you cant do that, only clips in the bins.
Jerry
