Activity Forums Apple Final Cut Pro Legacy Batch Increase Volume Of Source Clips?
  • Batch Increase Volume Of Source Clips?
    Posted by Eddie Kesler on August 18, 2011 at 5:53 pm
    I have a couple spot worth of source footage shot on Alexa and the sync audio is very low. Is there a way to increase the volume of all clips in the bin using a shortcut or command? I can of course manually do each one, but the Opt+Com+L only works in the timeline.
    Eddie
    https://www.jamedit.com
    John Pale replied 15 years, 1 month ago 3 Members · 2 Replies
  • Jeremy Garchow
    August 18, 2011 at 6:16 pm
    You would have to do it in the timeline, then drag them back to the bin.
    Or one by one in the viewer.
    Jeremy
  • John Pale
    August 19, 2011 at 3:38 am
    Or Batch Process the source files in Compressor. You will end up with duplicate files (but louder). Then reconnect to the processed files.
