Activity Forums Adobe Audition Batch increase amplitude valleys in Audition?
  • Batch increase amplitude valleys in Audition?
    Posted by Douglas Mccullough on April 20, 2008 at 5:26 pm
    I have several 30-minute wav files in which the speaker’s voice rhythmically rises and falls from 0 to -24. At 0 the volume is adequate, but at -24 barely audible.
    I could go through each file and manually increase the amplitude of each of these -24 valleys, but that really would be time consuming.
    Is there an “easy” method in Audition 3.0 to select these -24 decibel valleys and “batch” increase them to an acceptable amplitude?
    Douglas
    Mike Aurand replied 18 years, 3 months ago 2 Members · 1 Reply
  • Mike Aurand
    May 13, 2008 at 9:25 pm
    Try hard limiting. Set your peak level ( 0 if that works) and an average gain maybe 12db. That will boost everything 12db until it hits 0db. You may want to set the max at -1 to give yourself a little “head room.”
