Activity Forums Adobe After Effects batch import via CSV file
  • batch import via CSV file
    Posted by Antony Dupsta on January 11, 2019 at 10:53 pm
    Howdy,
    I have a data base that includes columns with shot names and paths to those shots. This exports from the data base as a csv file.
    Instead of manually importing 100 shots into after effects one by one, can I feed AE a doc that will do a batch import?
    Anyone come across something like this before?
    Meng Zhiqun replied 2 years, 8 months ago 4 Members · 3 Replies
  • Mark Whitney
    January 12, 2019 at 2:31 am
    Might OpenSesame do the trick?
    https://aescripts.com/pt_opensesame/
    Seems like I’ve seen other csv related utilities, but this is sort of the grandaddy.
  • Walter Soyka
    January 14, 2019 at 2:41 pm
    This should be pretty trivial to script. What’s the format of your CSV data? Can you post a little sample that shows what the CSV export looks like?
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Meng Zhiqun
    January 11, 2024 at 1:09 am
    HyperImport does that.
    https://aescripts.com/hyperimport/
    It allows local / online import, with .csv as well. Hope it helps!
