Activity Forums Avid Media Composer Batch import not working
  • Batch import not working
    Posted by Mike Halper on November 17, 2011 at 9:39 pm
    I’m trying to batch import a number of clips that are offlien using MC 6. It goes through the processing of what appears to be transcoding to DNxHD and then gives an error like “0 of 20 clips imported. See console.” In concole I get the following for each clip:
    Total AVCHD audio execute time is I64d microseconds
    Total AVCHD video execute time is I64d microseconds
    binImportMpeg – Audio tracks are longer than master mob.
    BatchImport::RelinkToMaster – IMPORT_TOO_SHORT
    Cannot reduce duration of clip shorter than current duration
    theMasterComp=1572 masterMob=1569
    Batch import clip 1 of 1 FAILED: 1J take 1 with error:
    Exception: IMPORT_TOO_SHORT
    Batch imported 0 of 1 clips
    The folders it points to for the original source files is correct. This was a 5.5.3 project that I’ve opened in MC 6. Any thoughts?
    _______________________________________________
    Mike
    Mike Halper replied 14 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
