Activity › Forums › Avid Media Composer › Batch import / capture
  • Batch import / capture
    Posted by Alejo Serra on February 21, 2010 at 4:32 pm
    Hello friends. I hope you can help me that I have some doubts with the batch import and batch capture.
    I am telling you.
    As I made a Bachte import, To recapture with higher quality, I have done over the clips, After erasing the media. Then I created a few new clips and past has left him in half offline, So the sequence is also in offline. If I replaced me on the assembly sequence correctly but I also created some new clips, Instead of replacing.
    This is so? How can I do to get some clips directly replaced by other?
    If hiciese batch after batch capture in import, Would equal? I would create some new clips? Recapurase a sequence only if I capture the footage included in the sequence?
    Alejo Serra replied 16 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
